ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Thu Feb 02, 2006 5:19 pm
94 Q45 T. 163,000 miles, the car seems like it doesn't want to take off from a stop, you can floor the gas and it doesn't matter it just starts to move slowly, but once the tach gets close to 3000 RPM it's like you hit a nitrous switch or something.
Other times taking off from a stop it's fine, 2 minutes later same problem as first paragraph, if I shift the trans manually it seems better.
When car doesn't want to go if you put the shifter into neutral the engine will rev fine I know it's not under any load when I do this but it seems like the engine is ok.
When car doesn't want to move out of it's own way I see no signs of the transmission slipping or RPM's rising like it was slipping.
A friend said the trans fluid smelled burnt and looked dirty, going to have transmission serviced soon, could problems just be caused from transmission not being serviced? and does the transmission use a metal screen filter that can just be cleaned or does the filter have to be replaced?
Thanks
