maxnix wrote:Let me ask you this, how do propeller airplanes fly? Which way does the propeller mechanism move through the air?
If they worked like you stated, planes would only fly backwards.
Be sure to post before you have breakfast with Mr. Beam.
Wellllll.....
Methinks that the centrifugal force of those spinning blades is going to determine where the loose bits go when it flies apart....not the fact that it's got a bit of yank on the air immediately in front of it. A DC3 once lost a prop and guess where it went? Right through the fuselage next to the engine, it did not meander ahead of the plane through some miracle of Bernoulli. Likewise there have been numerous instances of jet engines shucking compressor blades and they always go out perp to the axis of rotation...never forward. Hence my comment that his rad was probably out of harms way. Could the parts bounce forward? Well, perhaps....but I am not going to change my fan due to some cracked plastic. If you want to....Call Joe.
It's summer. The Beam is on the shelf except for the occasional julep. It's now Beefeater time.
