94 Q power steering leak question
ahardb0dy
Car: 1990 Nissan Sentra, 1994 Pathfinder Se, formerly owned: 2005 Nissan Titan, 1994 Infiniti Q45t, 1987 Nissan Hardbody SE-V6 4x4, 1980 Datsun 310GX
The area on the bottom of the power steering pump around the banjo fitting on the hose looks like it is wet,and the power steering reseivoir is constantly low on fluid, are the washers for the banjo fitting a dealer only part? Thanks
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
I would go dealer because banjo washers can be slightly off I.D & O.D. if aftermarket. Have you tightened hose fitting?
ahardb0dy
do you mean the banjo bolt fitting? Not yet
PopPop
ahardb0dy wrote:do you mean the banjo bolt fitting? Not yet
Yes!
