94 Q Noisy Rear End Differential
vroooooooom
Car: Q45
Have a 94 Q45 that is really loud in the rear. I think it is the differential. And believe it needs to be replaced. Local guy wants 1300 to replace .
Will a R200V work? Does it need to be specifically for my Q? :
rsiwicki
Car: 95 Q45T
buy a used one from a junkyard or from somebody parting out their Q in the classifieds sections for around $300 + $200 labor install (2 hour job max). It is rare to have a Q45 diff fail so buying a used diff is a good bet. For $1,300 you could have a custom made 4.08 vs stock 3.54 rearend made.
FarFetched
Car: Suzuki SV1000S.
rsiwicki wrote:buy a used one from a junkyard or from somebody parting out their Q in the classifieds sections for around $300 + $200 labor install (2 hour job max). It is rare to have a Q45 diff fail so buying a used diff is a good bet. For $1,300 you could have a custom made 4.08 vs stock 3.54 rearend made.
Y33 is way better in that respect. I got 4.083 diff for 35$ zerothread?id=136080It took me ~2.5 hrs start-finish to get it in. I think Q45 should have 4.10 (4..083) diff from factory!It is a beast now!Cheers!
I just bought a 4.11 from a GT-R for $350.
As soon as I swap it, I'll have a "slightly noisy" 4.08 available, it whines a bit but works good; AND a 75K mile OEM diff (3.54 ratio).
vroooooooom
Car: Q45
That's an awesome deal.
Do you think this would fit?
http://cgi.ebay.com/ebaymotors...ZWDVW
FarFetched
I don't see ABS/TCS sensors !I am not familiar with G50 Q45 so I don't know !
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
loks like 5-point half shaft flanges. the 94 needs 6 point, or custom half shaft spacers.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
hitman- this R33 diff it is a 6-point? why have we not heard of this replacement for our G50s before? was i sleeping?
rsiwicki
Car: 95 Q45T
dude...that is a 240 diff....you need a Q45 diff and besides that diff is a rust bucket. you can do much better than that.
Q451990
Probably a dumb question... but you're sure it's the differential and not a noisy fuel pump?
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
GQ Jay wrote:hitman- this R33 diff it is a 6-point? why have we not heard of this replacement for our G50s before? was i sleeping?
I think that all the Q guys were sleeping!!
FarFetched
What is R33 diff?curious!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
so what is the dilly?? what year skyline did it come out of ?? where is mine?? Wes were u sleeping as well? is it a perfect match ??
elwesso
2007 BMW M Coupe
James... ring me sometime, that was that "thing" i needed to tell you during our last converstaion!!!
1) Yes.2) Because they're almost impossible to find.3) Quite possibly.
elwesso
2007 BMW M Coupe
Remember that R32-R34 are all interchangeable..... It doesnt have to be from the GT-R just has to be a skyline 4.08
vroooooooom
Car: Q45
The whine doesn't vary with engine speed, only forward motion. But thanks.
vroooooooom
Car: Q45
AZhitman:
Would be keenly interested in your cast off OEM diff. Want year and how many miles? I am in So. CA.
jamesmost
TCS ???
elwesso
2007 BMW M Coupe
Yeah theyll work with TCS
RobertsnewQ
Wow - I've checked out a lot of skyline diffs and I've never seen a 6-bolt flange. Must all be from R32s or GTs-ts.
Also, they are a slightly different ratio - 4.11 as opposed to the 4.08 we're used to seeing.
Different ring and pinion than the Z32 / J30 / 180sx commonly found.
vroooooooom
Car: Q45
Sounds like I'm really better off with a genuine Q Diff. Are all years swappable?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
vroooooooom wrote:Sounds like I'm really better off with a genuine Q Diff. Are all years swappable?
No as FY33 are different from G50, but G50 TCS requires 4 channel ABS connections and axle rotation sensors as opposed to other 3 channel driveshaft speed sensor.
elwesso
2007 BMW M Coupe
the active Qs had the extra speedo sensors, as well, iirc... So getting one from a TCS OR active G50, you should be in business.
I still have my stocker with low miles, but shipping would be a PITA (it's like 80 pounds).
jamesmost
elwesso wrote:Yeah theyll work with TCS
Will A Diff from a Bluebird work ??
elwesso
2007 BMW M Coupe
Those are FWD! (assuming you mean like altimas and stanzas)
jamesmost
elwesso wrote:Those are FWD! (assuming you mean like altimas and stanzas)
is that what a bluebird is? gotcha
Spoke to some JDM importers no helpMy friend does some work w/a JDM importer in NJ, said he will talk to him tonight about getting a few in the next container So u r saying R33 is exact?what about r32 and r34??
Modified by jamesmost at 3:46 PM 9/26/2005
jamesmost
GT-R 4:3:1GT-S 4:1:1Just read that in another forum??
