landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Fri Oct 25, 2002 6:38 am
Since the plenum has to come off for #3, this will be expensive. Injectors are $150 ea. from Scottsdale, so you're cooked anyway you look at it. Plenum off and two injectors would be minimum $1000, probably more like $1200.
So, you've already spent at least $1000. How can we keep this from getting completely out of control?
In for a penny, in for a pound? You'll pay $700 to take the plenum off again when/if the next injector fails. Since your injectors seem to be failing at an alarming rate, you could spend an extra $1000 - $1500 this time and get all-new injectors, gamb|ing that you'll save the $700 plenum off/on a time or two.
My plenum most recently came off for coolant leaks caused by a dealership mechanic replacing the knock sensors, courtesy the previous owner. It might not be long-term smart to disturb the plenum without replacing nearly everything under it that may fail under normal use, including knock sensors. Replace all the under-plenum hoses, too ($200 - $400 ka-ching!) for the same reason. The added resistance problem could be in the injector wiring harness, but you won't find out until the plenum is off.
This all begs the question -- how long do you want to keep the car? Me, I would rather do it right the first time, hold on to the car to "drive" value out of your preventive maintenance investment. It sure beats lease payments.
OR
Word is that you can get to the outboard 4 injectors w/o plenum removal -- I don't have any reason to doubt that, but I've never done it. I think this is originally Fred's suggestion -- you could put your oldest 4 (most likely to fail) injectors in these outboard positions, put 4 new ones under the plenum. That saves $600 this time compared to option 1, and is only $300 - $500 more expensive than replacing just the 2 that are bad today.
Don't fool around with "remanufactured" injectors. When replacing just one injector might be a $1000 adventure, the $100 you might save seems pretty pitiful.
You're in for $1000 minimum. You could easily be in for $3000 to "do it all," but you really would have done a lot. This is of those times when you ask yourself how much more use do you expect to get out of the car. Me, I cut all my bills down by at least half, sometimes 75% by doing it myself. Not for everyone, but it helps me make sense out of keeping the Q.
