94 q 45 stalls
wolfpck2
have a 94 q with 250 thou on it recently it wants to stall out sometimes like its not getting fuel also sometimes in the morning ill turn the key hear the pump pressuring up in back but when i go to start the car nothing for a few seconds sometimes then it finally starts any ideas are both related or seperate? thanks jim
That was a really, really, really long sentence.
Lets do a recap for the viewing audience:
VEHICLE:1994 Q45250,000 Miles
SYMPTOM 1:"it wants to stall out sometimes like its not getting fuel"
SYMPTOM 2:"sometimes in the morning ill turn the key hear the pump pressuring up in backbut when i go to start the car, [it does] nothing for a few seconds sometimes, then it finally starts"
QUERY:"any ideas?are both related or seperate?"
DrewQ45
Car: 1990 Infiniti Q45
When is the last time the fuel filter was changed?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I think you need too post this in Infiniti Mechanic Forum after searching on fuel pump, fuel filter and FPCU only if you cannot determine the answer.
Oh, and please make it readable.
96Qowner
Car: 1996 Q45
Sheesh guys, give the guy a little slack.
Any of three things, I can think of.
1. Maybe a bad pump, yeah. They last 100,000 miles, give or take 40,000, so yours is probably due. Also, if you don't change it when it starts to fail, it can and will, fry the pump controller, which is more expensive than the pump. If it's whining loudly like a swarm of bees, get it replaced pronto.
2. A bad MAF can cause stalling problems. There's a procedure for cleaning it at http://www.q45.org.
3. Low transmission fluid level. It doesn't expain the hard starting, though, so probably not that. Check the level anyway. If it's low, the torque converter can lock up as you're coasting to a stop and stall the motor.
Modified by 96Qowner at 9:24 AM 2/1/2006
