atraudes »
https://forums.nicoclub.com/atraudes-u214401.html
Wed Feb 24, 2016 9:27 pm
Run a garden hose up to your windshield and stream water into the cowl below the windshield. Then you can open the doors, look in the jamb, and verify that water is flowing out of the bottom of the car via the drains properly.
I could also be a leak in the wheel well. I'd pull up the carpet to the metal and see if you can see any gaps. The only other thing that would cause moisture like that if it's not external water is a plugged drain for the A/C.
