94 Pathfinder Crankshaft Bolt
JRail1
Car: 94 Pathfinder
I recently put a new engine in my pathfinder and need to tighten the crankshaft bolt to 90-98 ft lbs...only problem is I don't know how to stop the engine from turning so that I can do this...Is there a trick somewhere.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Use a chain wrench..... You can get them at sears and things like tha.t what you do is wrap the chain around the crank pulley, and then hold the chain wrench while you tighten.. as you pull tighter on the chain wrench, it will pull tighter against the pulley.....
JRail1
Car: 94 Pathfinder
Hey Thanks...I actually used a strap wrench but it worked the same way...
elwesso
2007 BMW M Coupe
Yeah that will work, but a lot of times when your dealing with torque values that high the belt breaks...
JRail1
Car: 94 Pathfinder
Yeah it was laying around so I figured why got to the store if I didn't have to...Posted another one about the engine, starts but wont stay running, post is right next to this one....any ideas...
