94 pathfinder 4x4 frame rebiuld
Nismoskyline350GT
Car: 03 Nissan skyline350gt
87 d21 nissan 4x4 pick up
03 nissan altima 3.5 se
94 nissan pathfinder
Hello, anyone that is interested I'm doing a frame rebuild
I have AUTO CAD FILES that I have created. I have found that a lot
Of pathfinders frames rotted away but the cab and engine
Was still in excellent condition. So I am reviving this pathfinder
To ride again..........I've got pics of my progress
Last edited by Nismoskyline350GT on Tue Feb 21, 2012 5:35 pm, edited 1 time in total.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Pics of progress will be nice. Lots of Pathys bit the dust years too soon because of rotten frames.
solyoung
+1... I'm interested in the project. Anyone got links or resources for a total frame-swap or frame upgrade how-to?
Nismoskyline350GT
you will probably not be able to see the cad files sorry
I have been taking pictures of the whole project
( found in my research its about 104.5" from center wheel to center wheel for alignment)
this frame wow
enjoy oh if you want to know the degree of angle I used it was 10 degrees
My Dad and I cut V out of the steel then heated it to bend and welled it. there are
some out there that cut the tube in half and re-weld this does make it harder to keep it straight, from the heat in the welding process. my frame is complete attached one-piece tube. we cut 1-3/4" out of the first and second bend and 3/4" out of the last bend.
Last edited by Nismoskyline350GT on Tue Feb 21, 2012 5:39 pm, edited 5 times in total.
Nismoskyline350GT
decided to use leaf springs off a 92 nissan 2wd truck so far so good
I also had to cut all the mounts off the excising pathfinder axle and will have to
make a mount for it to set on the leaf springs just like the 92 nissan 2wd truck
Nismoskyline350GT
here is the how far back we cut it
Nismoskyline350GT
from just after the front door all the way back totally junk its amazing that it held together
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Wow, that's pretty bad, some of the worst frame rot I've seen on a Pathfinder.
Clean looking Pathfinder. Is it an auto or manual?
Good luck with the frame repair!
Nismoskyline350GT
The pathfinder is AT 4x4 .
Towncivilian
You may want to look into bypassing the stock transmission cooler at some point, if you haven't already done so. It's been known to clog and kill the transmission.
Nismoskyline350GT
Thanks for the tip will do
ddennett
Car: 1995 Nissan Pickup
Sorry to revive a old post, but I am looking at trying to fix/rebuilding my 1995 Nissan pickup frame, which is in about the same condition (if not worst) as the one from your pathfinder. I am thinking that I might have to junk it, but wanted to see if you were successful with your fix and if so how has it held up over the past couple years.
Thanks
Nismoskyline350GT
I was very successful with the rebuild . I have more pictures to post . if you want help with it my e-mail is [email protected] . I have a 87nissan pickup for sale if you want to see it here is my craiglist post. http://fortwayne.craigslist.org/cto/4548980576.html
