crulf8 »
https://forums.nicoclub.com/crulf8-u99856.html
Tue Jul 01, 2008 10:38 am
I have narrowd it down to a quandry. the fuse does not blow when the vehicle is idleing. the stereo both direct and ignition is not in this circuit.The air conditioning blower is and you can run it while the fuse is still good and it does not blow the fuse there is something called an electronic fuel module or somesuch that this little 10 amp fuse is responsable for. if the vehicle is hot and you put in a good fuse, it blows right away. If the vehicle is cold you can put a new fuse in it and it will not blow right away.when you drive the vehicle it blows as far as i know at this time the fuse runs the dash guages, the a.c. blower, the seat belt chime, the fuel module, and the hazard lights. I have a manuel although its a nissan truck manuel from 1980 to 1996.I put a new alternator because the battery light comes on when the rest of the dash goes bad and it did nothing besides showing me I can still replace an alternator. I need a pathfinder expert. Still perplexed
