http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0133804707
Tune Up Kit Nissan Maxima 1989-1994 VG30E SOHC
Includes:
* oil filter
* fuel filter
* air filter
* PCV valve
* distributor cap
* ignition rotors
* six NGK spark plugs
* NGK spark plug wires
Thanks for the response MotleyS13, much appreciated. Yeah bro, I got it diagnosed by pep boys last week, and was told a tune up should be done. I don't have a check engine light on, but I noticed the car hesitate when at a red light and idles low. I'm not a mechanic nor do I have the tools, So I don't think I could work on it by myself. Although I would like too to save me bucks. What else should be changed? Should all the fluid be replaced too? I just had an oil change not too long ago, so I know that's ok. But what about transmission fluid? Brake fluid? Radiator fluid?MotleyS13 wrote:i would be extremely weary of the plug wires and dizzy cap. If they actually diagnosed the vehicle and didnt just say a tune up like most shops do, then id buy the kit and maybe replace a few key parts where quality might be a factor. cheapest way id say is buy the kit, buy a fsm (factory service manual) and take your time. its quite simple and the fsm will take you through pretty much step for step.
Thanks for the response, can you please list some good cleaners? Much appreciated.rioredstang wrote:You should be able to this work yourself. I own a shop and we don't like to install customer parts. We try to make a profit off of parts and labor. With that said, I think you are right on with the maint. work. Install the plugs, wires, cap, and rotor. Also clean the throttle body and mass air flow meter. They sell these cleaners at the parts store. Do the fliuds as your money allows. I would flush the trans & rad.
