94 Message Board question
clutch Kick drifter
Car: 1992 Nissan 240sx/ Blacktop SR20det
I currently have a 240 and about to get a Q45. Only thing wrong with it is he message board needs to be reset? is this a common problem, easy problem to fix? also so i dont make another thread , will a 18x11 + (0-10) and 18x9 +(0-10) fit with running like a 265 40 18 and 225 40 18? Just seeing if something that baller will fit and if so then i can get anything below it. Thanks guysTC
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Message board? you mean the digital display on the instrument cluster? Whats it say?
Unless you put a dry erase board somewhere on the car, Im not aware of any "message board" anywhere on a Q45.
clutch Kick drifter
yeah im pretty sure he means the digi display. hahaha dry erase!!
Q451990
There's no resetting it... you fix what's wrong - or hook that particular input to something to fool it, usually ground. Let me guess... it says "Brake Pads Worn" or "XXX Lamp Inoperative"
Heath
Rex
Car: None
clutch Kick drifter wrote:I currently have a 240 and about to get a Q45. Only thing wrong with it is he message board needs to be reset? is this a common problem, easy problem to fix? also so i dont make another thread , will a 18x11 + (0-10) and 18x9 +(0-10) fit with running like a 265 40 18 and 225 40 18? Just seeing if something that baller will fit and if so then i can get anything below it. Thanks guysTC
There are a few fitment threads, but I can tell you very few (search posts by onetongarage) go for "baller fitments" and stretched tires.
clutch Kick drifter
I just found some, just didnt change the post ! Yeah it says something about the rear brake light and something else, im pretty sure he dosent know what hes talking about lol.
For the tail lights, you usually have to replace the whole plastic bulb assembly at this point. Its a $20 part, two minutes to install. The new assembly comes with new bulbs too.
ILuvNkdChx
Car: Q45t, I30t
elwesso wrote:Message board? you mean the digital display on the instrument cluster? Whats it say?
Dry Erase Board...Sorry I had to post that again because it's just that funny!!!
