'94 Maxima transmission Service
JT_MONEY_2004
Car: 1990 Q45, Pearl
I have a early 94 Maxima, transmission fluid looks good but hasn't been replaced in atleast 2yrs. I wanna do it this weekend, i found out there isn't a pan/filter to drop and replace, so... is all i have to do, just drain & refill a few times to clean the system? ...or should i get the system flushed.
NOTE: When i got car two yrs ago the fluid looked very clean so i left it alone. I have NO SERVICE HISTORY on this transmission so please consider that.
Also plan on fuel filter replacement this weekend and possible throttle body cleaning...
s13sr20chris
drop the drain plug and fill her up. easier than an oil change. do that as many times as you want(2 should be adequate).
JT_MONEY_2004
Shop across the street from me says it's 1.5 hrs labor, hence, $90 labor....RAPE.Thanks for the confirmation and quick reply, you're appreciated.
s13sr20chris
1.5 to drain and fill? holy cow! i wish i could swing that. my conscience would bother me.
