94 Maxima Problems
glacier985
Car: 72 Datsun 240Z
90 Nissan 240SX
11 Subaru WRX Wagon
16 Nissan Rogue
Okay, I have a 94 Maxima SE with the VE engine, history of the car with me and stuff I've done.
1. #6 Injector went bad, replaced, Problem Fixed.2. Had Starting problems, was told to replace injector o-rings on the leaking injector. Found #1 injector was gasy, pulled and replaced both bad o-rings. Problem Fixed.3. Car ran good for aobut 3 months, now the starting problem is back. Need to press the gas all the way down to start the car.4. Another problem developed, with the check engine coming on and going off. When its on the car, seems to studder and accelerate slow. And then suddenly just take off.
Any ideas??
I'm guessing knock sensor? And o-ring(s) went bad?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
glacier985 wrote:I'm guessing knock sensor? And o-ring(s) went bad?
Sounds like it.Is there a gassy smell to the exhaust immediately after startup?In a situation such as the knock sensor, I always like to test it with a known-good sensor if one is available.
Also, you might find this thread helpful. The situation isn't identical, but it's close enough that the info might be of use to you.
glacier985
Car: 72 Datsun 240Z
90 Nissan 240SX
11 Subaru WRX Wagon
16 Nissan Rogue
Yes, the exhaust does smell gassy after startup. What if I can't get a good know tester, could I use a 10Mohm resistor in its place to check if its bad?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
glacier985 wrote:Yes, the exhaust does smell gassy after startup. What if I can't get a good know tester, could I use a 10Mohm resistor in its place to check if its bad?
I'd actually test the injector itself for proper resistance. 10-14 ohms is normal. But if you don't have a multimeter to test with, just go with your method.
NISTECH
check your coolant temp sensor connector for corrosion, also you NEED to pull the code to verify your problem. there are only so many codes on that car.
glacier985
Car: 72 Datsun 240Z
90 Nissan 240SX
11 Subaru WRX Wagon
16 Nissan Rogue
okay, I'll check both those out tomorrow and post them up.
glacier985
Car: 72 Datsun 240Z
90 Nissan 240SX
11 Subaru WRX Wagon
16 Nissan Rogue
got code 34, which i think is the knock sensor
also noticed that the check engine light is not on again
NISTECH
knock sensor wont create much of a run problem, however it also wont illuminate the CEL. So you had another code in there but it cleared when the problem went away.
How did the sensor connector look?
glacier985
Car: 72 Datsun 240Z
90 Nissan 240SX
11 Subaru WRX Wagon
16 Nissan Rogue
I just remebered and checked the sensor connector today, it was corroded a little bit with white calcuim looking stuff, so I took some rubbing alcohol to it and cleaned it. The car was already running better today and has been running fine all day, so not sure if that fixed the problem.
