94 Maxima blower fan not turning off
JLR_94_Maxima
Car: 94 Nissan Maxima
Hello All,
I bought a used 94 Maxima for my kids, only 102K miles, engine in great shape. The bad news, the interior fan will not turn off, regardless which switch (auto/manual) is selected or the speed. The fan speed does change from low to high and the heater seems to warm up OK, but there isn't an off setting. Any suggestions?
Thanks, John
ilovesideways
Car: 240SX S-13 KA24E
hey I think you might get more answers if you put this in the maxima forums
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Since you mention "auto" mode I'm assuming the car has digital climate control? Does it look like this?http://imagehost.vendio.com/a/...G.jpg
JLR_94_Maxima
Yes, that looks like the controls for the blower, the display has a fan that goes from 1 - 4 blades based on the speed. The off doesn't work, it always blows air.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Sounds like the controller is bad. Your best bet is probably to disconnect it. The dash is pretty easy to open up. Once in there, you should be able to disconnect the HVAC controller. If that doesn't stop the fan, you probably have a bad blower motor controller. If it DOES stop the can, you should just need to order a replacement unit. You can probably replace it with a manual unit if you want to save some cash.
