94 J30t Turbine Sensor Replacement... Help!
halfbyte
Greetings all;I am planning on replacing the turbine sensor. Does transmission had to be dropped?Has any one had an experience replacing one of this?
Thanks in advance.
driverdriver
Car: NICO's longtime resident Canuck!!!
Is the turbine sensor the same as the transmission revolution sensor?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
look for post by 'farfetched' he did this on a 97Q [re4r03a]. might not be exactly the same on an re4r01a.
FarFetched
Car: Suzuki SV1000S.
From looks of it (ALDATA) the procedure is the same. Turbine sensor is on top of transmission. I can't say if it is the same, I've never looked at it on J30!I am sure you would have to lover engine/suspension cradle to get access to it. If you are not equipped for such repair let a good INFINITI-ORIENTED mechanic do it. Cheers!
halfbyte
Just replaced the turbine sensor on my 94 J30t.
Took about 15 mins from start to finish. I am not too sure as to why Inifiniti
dealers need to drop transmission for this... I was able to remove and replace.
FarFetched
Was it located on the end of transmission housing ?Cheers!
halfbyte
Yes it was. The difficult part of the job was routing the wire.
Q45tech
CONFUSED? Turbine vs Speed sensor
halfbyte
Q45tech wrote:CONFUSED? Turbine vs Speed sensor
It was a turbine sensor. Here is the part number ( INF 31935-51X60 SENSOR ASSY-TURBINE)
FarFetched
There is a revolution sensor (rear of transmission) and turbine revolution sensor (top of transmission where bellhousing meets transm body) .What shape was the sensor?Quote »1995 Infiniti J30 V6-2960cc 3.0L DOHC (VG30DE) Vehicle Level Transmission and Drivetrain Sensors and Switches - Transmission and Drivetrain Sensors and Switches - A/T Transmission Speed Sensor Information Hide Details Testing and Inspection • Revolution Sensor • Turbine Revolution Sensor Parts and Labor • Replace Specifications • Revolution Sensor • Turbine Revolution Sensor © 2006 ALLDATA LLC. All rights reserved. Terms of Use [/quote]As you can see there a difference between two sensors.P.S Not to make you wrong, but I've done turbibe rev sensor bot on J30 and Q45 (Q45 was first). Let me tell you it was not 15 min job Cheers! P.S (2) Look on the attached picture that is turbine revolution sensor
halfbyte
Yes, it was the turbine revolution sensor located on top of the tramsmission where bellhousing meets the transmission body.
Yes, it is the one that shows in the picture that "FarFetched" posted
And yes, it took me about 15 mins to pull out the sensor and replace. I wan't including the time from jacking up the car... but if I may, from jacking up the car to clean-up, it's more like 45 mins. Sorry for the time(duration) confusion.
But for sure, this job does not require you to drop sup/cradle or the transmission on 94 J30t.
Cheers~~
FarFetched
Then I migh ask, why I had to lower cradle when I did R+R on J30. I didn't have to lower as far as on Q45 but I needed some clearance to get it out. Next time I am doing J30 I will try it w/o extra time Cheers!
halfbyte
Farfetched,
I was planning on doing the susp/cradle drop just like you did.But when I disconnected the harness and unbolted two bolts it came right out. I was very surprised too
If you have to replace another one next time, just try it... you will be surprised as well...
Cheers
FarFetched
Cool!Next time should be a bucket of to do one of these puppies!
mari79
my 1993 infiniti j30 has shifting problems when i drive in town doing 25 mph,but when i drive on the highway doing 65 to 75mph it drives fine,could that have to do with my tyurbine sensor?
