autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Sun Mar 07, 2004 9:41 am
While the engine is warm and at idle, you might try and reach under the EGR valve and lift the valve off of the seat and see if you get an engine stumble. One sure way to find out if you have an EGR clog, but also depends on where the clog may be located. One way the ECM knows that the EGR has a malfunction is from the EGR temperature sensor, which as the EGR flows past the temp sensor the voltage will decrease in value. Most cases, the voltage will be around the 1 volt range when you have (no EGR) flow, and the voltage will decrease when you do have (EGR flow). There are no real specific values on that particular sensor due to the hot and cold ratio will somewhat affect the reading. The ECM is looking for the change in voltage! In my experience, 99% of the time with that particular trouble code, the EGR tubes are clogged, after the cleaning of the EGR tubes(right and left sides), I would recommend a BG air induction clean.
