driverdriver »
https://forums.nicoclub.com/driverdriver-u9137.html
Fri Aug 24, 2007 10:20 am
If you want to keep the car awhile and do it proper then remove the plenum and intake. Depending on the injector there is a method to change out the injectors using a dremel to kind of bore into the side of the intake or plenum. The only drawback is if you or the mechanic miscalculates just by bit your looking at forking out some major cash for a new intake/plenum.
