So, as anticipated
the cam seal is now leaking oil onto the timing belt of my '94 J30, which is now at 179k miles. I'm now wanting to keep this car, but have to budget out repairs, if at all possible.
If I get the cam seals and the timing belt if it's too oily (it was replaced at 109k), is the location of that repair (quoted at 4.6 hours) such that the valve cover gasket (quoted at 5.2 hours) could be done later? I don't know enough about the internal workings under the hood to know whether the valve cover has to be removed to get to the cam seals.
The shop is also thinking the oil pump may need to be replace - and, holy cow, that's another 5.4 hours labor + a quote of $305 for an OEM pump.
Any advice will be much appreciated.
