ceningolmo wrote:Wow... that's encouraging. Nice purchase, hope you're rich?!
Anyway... of course you will spend what you are comfortable with, but it is unlikely that you will need to spend that much just to get it to a well maintained status. If you have the funding to restore it across the course of the next couple of years that would be great... of course, we would love to see every Q fully restored and one the road. Realistically though, I realize not everyone will do that.
Not rich, just well budgeted. Remember, he wanted reliability. There is no reliability without maintenance, and preventative maintenance is cheaper than expensive mechanical parts and systems.
I rather suspect, since he did not mention otherwise, shocks and all the rubber is gone, so that is ~$450 for parts alone.
Same with under plenum hoses. Another ~$450 with plugs which are probably due. Also the EGR, IAC and TB along with the plenum itself.
Labor for the above could be really spendy.
Tires? Hmmmm.....what tires in 15"? So now one has to think of wheels and tires.
No transmission flushes? No auxiliary ATF cooler? Better start saving. Time left can be judged by the color of the fluid. Same for the PS fluid.
Then there are rotors, pads and shim kits. All fluids and filters.
I think I am conservative. Read Q45tech's posts. They are pretty simply worded on this topic. Usually anywhere form $3K to $11K to rehabilitate cars he sees.
