somedude »
https://forums.nicoclub.com/somedude-u65018.html
Thu Jul 10, 2008 3:00 pm
I just came across a Renault 4cyl turbo-diesel engine out fo a small RV and i'm planning on swappin it in the HB. Getting the engine to run wont be hard since its all mechanical for teh most part(injection, etc). My concern will be the HB wiring. If its possible, i want to use the 5-speed thats in the truck. So i want to use the factory speedo, and possibly the temp gauge too. So the only gauge i'll have to get is a tach. Do i need the HB ecu for those? And what is the hp rating for the KA that is in there right now? The tag on the renault says its rated for 75@3750rpm. also, if anyone would like to help a feller out, i've been searchin for some additional info/specs on the renault without much luck. so if you find yourself bored. . . . . Thanks
