nalz »
https://forums.nicoclub.com/nalz-u230622.html
Tue Nov 03, 2015 12:18 pm
A situation where there is spark(@ the spark plugs), a strong fuel smell out of the tailpipe, AND the engine cranks over fast: sounds like a valve timing issue.I know you mentioned a tight timing chain, but you should really check to see if the camshaft timing marks line up, and do a compression test. If your engine is cranking too fast, it is due to low compression, and it will show up as low and uneven compression between cylinders
