94 hardbody
nissandillon
Car: 94 D21 extened cab, 93 240sx hatch
I have a 94 nissan hardbo]dy with v6. It had a saty leak so I went in the fromt and I am running into more problems as I go Image
http://s741.photobucket.com/user/nissan ... sort=3&o=1
This part is broke and cracked in several place and will not slide off the shaft for anything I see what seams to be a lock ring holding it to the shaft but I was also told the thing should slide off.
This is a view of the bottom of the shaft.
http://s741.photobucket.com/user/nissan ... sort=3&o=0
Any help would be greatly appreciated never worked on one of these things
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I guess I am having a hard time understanding what you are trying to replace. Are you trying to replace the front crankshaft seal?
nissandillon
That was my intentions do I need to take the entire cover off that the seal in the picture is in
