94 hardbody stuck/broken speed sensor help
Kpo
Car: 1994 Nissan Pickup 4x4 Standard
So I was trying to remove the VSS from my 94 Pickup and it broke and hours of struggling trying to pull it out and many bloody knuckles later it's still broken in the transmission any input on how to go about removing it would be appreciated.
http://img856.imageshack.us/img856/5729/1yj8.jpg
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
It sucks because of the location of the sensor. You might have to pull the transmission and lay it on a work bench, it will gain you an advantage without the cross member being in the way. One other thing you can try is removing the shifter and trying to attack it from above rather than below. Since the sensor is toast now you can't hurt by using some persuasion.
