chomer »
https://forums.nicoclub.com/chomer-u52925.html
Wed Jan 03, 2007 4:34 pm
Want to double check with the pros before I do anything "stupid"....
Anyways, saw the helpful guide on Q45.org on removing the glove compartment. Would it be safe to assume that replacing the darlington transistor (or is that a resistor?) would fix the problem?
Symptoms: On either auto or manual, only fan speed high would work. Off also works (as opposed to some other people on the board).
Bonus: What else should I be doing while I'm in there? I saw the pictures of the evaporator core cleaning. Anything else?
