So far I can't find anything on this subject. Not even the FSM goes into detail.
My CFM seized up against my condenser coil. I have the motor to replace it, but cannot see any way to replace it without removing radiator,condensor fan (vacuum a/c system;recharge).
I had all the bolts loose including the entire headlight assembly, but all of the front frame components are welded together.
Anyone tell me there is some way to fix this without removing half the front end.
