autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Tue Jul 15, 2003 8:42 pm
All of the G-20 Infiniti models are chain driven. The engine would still start regarding the fail-safe (limp home) mode. No start conditions could result for numerous reasons; luckily you have purchased a vehicle that isn’t too difficult to diagnois. One thing I would like for you to look at, remove the oil filler cap, look down on top of the camshaft with a flashlight to make sure the camshaft hasn’t started to seize by a lack of maintenance. If everything looks fine there, go back to the basics. Is the plugs firing, fuel pump working, injectors pulsating, cylinders washed out with fuel resulting in very low compression. If your not mechanically inclined I would have a technician diagnosis. With you having no history of the vehicle or when it was last running, the problem could be anywhere. A few unusual no start situations I have seen, a customer putting diesel fuel in the tank at the pump. That type situation can drive techs up the wall, depending on the gasoline/diesel mix. Don’t think nahhhhh, nowadays with all that’s going on with engines, sometimes, seeing is believing!
