94 G 20 with problems
todfun
Car: 94 G20
have a 94 g20 that was running rough, Scanner said knock sensor and injector. Put in a new set of injectors and now it starts fine and idles but after a min or so it spudders when you rev it. Idea's?
nametakennow
Car: '06 MINI Cooper S
Since it said knock sensor as well, that's probably the culprit.
Does it just sputter or does it not rev or stall?
Welcome!
todfun
Car: 94 G20
Thanks for answering, Knock code is gone. It spudders then will rev a little. Checked fuel pressure and it's ok
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Sounds like you still have an injector problem or one is leaky and flooding the cylinder. Did you use some type of lubricant on the injector o rings when you put them back in the fuel rail?
todfun
Car: 94 G20
Yes, I used silicone spray.
