elwesso wrote:You dont need help bro, its not hard.. Heres the crash course (ive done this 3 times)
BEFORE YOU DO ANYTHING, DEPRESSURIZE THE SYSTEM. PULL THE FUEL PUMP FUSE AT IDLE.. ITS THE 3RD ONE DOWN ON THE RIGHT HAND COLUMN, WITH THE FUSE PANEL ON THE DRIVERS SIDE.
Remove the rear seat bottom, with the two little black things on the floor... Pull out, then pull the seat up
Remove the seat back... 4 screws on the bottom and 2 behind the little flip down console thingy... What I did is removed the bottom seat belt thing in the far right corners and then pulled it up through the seatbelt thing
Remove the rear package shelf... This took some finesse, but dont give up, a little firm but not "yanking" brute force will get it done...
Pull the black box thing... 6 screws...
undo the fuel lines on the pump
undo the fuel pump screws
pull out pump
Reverse order and be sure to install a new O ring
I can give you a step by step over phone...
Before you run the car out of fuel from fuel starvation, remove the gas cap, to relieve the tank pressure. This should help with the fuel leakage while removing the gas lines. I have not done one yet, but have the pump, and am waiting for some free time, to do it.
