float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Apr 07, 2004 7:35 am
I believe they were all emmision's type things, and unless that is a concern, you should be fine. DO NOT, use jumpers as there needs to be some load on the circut. You can burn up the circut/fry your ecu if you do that. Leave all three unplugged and see if it starts. If it does, drive it for a half hour or so, and then see if you ecu throws any codes.
