VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Feb 10, 2025 8:53 pm
The tacho on a '94 VG gets a square wave signal from the ECM on a White wire, pin 33 at the cluster. Start by seeing if you have a "middle voltage" (probably half the battery rail) there with the truck running. If so, the problem is in the cluster and not the signal. If not, the ECM gets its signal from the power tran-sistor (PTU), and there's a 2.2K dropping resistor in between the coil/PTU and the ECM which will kill the tacho if it's open circuit. That would be the prime suspect. Should be located around the driver's wheel well IIRC.
The speed sensors have an o-ring that's located about 1/4" down the bore of the hole, and the area outside the o-ring can cake up with corrosion. They don't usually seize hard enough to break the sensor housing when twisted, but to be safe, I'd give it a long soak with WD40 before trying to remove it. Crud on the bore wall can also make the o-ring very stubborn, so expect to do some twisting and prying on the housing to get it loose.
