guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Wed Sep 20, 2006 8:34 am
The EGR wont affect the transmission shifting. It will make the engine run like crap if it is stuck open, but thats it. If its stuck closed, you'll never know the difference.
As far as the TPS, if you look at the first picture posted (not sure what that second one is from), you see the plug attached to the wires, but you also see 3 electrical contacts on the TPS itself. On your TPS, you need to disconnect the plug to get access to those contacts so that you can adjust the TPS properly.
You will need a multimeter to check for continuity (any el-cheapo $8 multimeter will do). You are going to need a helper. I'm going to write this like you have no idea what you are doing. It will actually sound more complicated than it is. Its actually really easy and shouldnt take more than a half hour or so.
WITH THE ENGINE OFF AND YOUR FOOT OFF THE GAS PEDAL, there should NOT be continuity on the bottom two contacts. If you have continuity between the bottom 2 contacts, with your foot off the gas pedal, the TPS is screwed, replace it.
WITH THE ENGINE OFF AND THE GAS PEDAL ALL THE WAY TO THE FLOOR, there should NOT be continuity on the top 2 contacts, there SHOULD be continuity between the bottom two (by now you have seen that obviously with 3 electrodes the middle one is always part of the checking). If the TPS fails this check, its screwed, replace it. If its ok so far, keep going.
Now, start the engine and just barely touch the gas pedal until the rpms sit between 900-1100 (the manual I think says 900 plus or minus 150, just shoot for 1100, it makes things easier, thats where I set mine and it works fine). There should NOT be continuity on the top 2 contacts OR the bottom 2 at 1100 rpm. (Note: Stay clear of the fan while you are doing this!) If you have continuity between the BOTTOM 2 contacts at 1100 rpm, the TPS is bad, replace it. If there is continuity on the top 2 contacts, its probably just out of adjustment (stop the engine). Loosen the screws that hold the TPS to the throttle body (you will need to small hands and/or small tools to do that) and rotate the tops of the TPS just a SMALL bit up, or towards the back. Tighten the screws (just snug enough to keep the TPS from rotating, they dont have to be really tight for now) and now see if there is continuity on the top 2 contacts at 1100rpm, if so its still out of adjustment. Loosen the screws, rotate it towards the back a tiny bit, tighten the screws, start the engine, put it to 1100 rpm, and check the top 2 contacts again. Keep doing this until the top 2 contacts have continuity at idle (foot off the gas), but no continuity at 1100 rpm. If you cant get it to do this, get a new one. If you can get it this far, tighten the screws. WITH THE ENGINE OFF AND THE GAS PEDAL ALL THE WAY TO THE FLOOR, there should NOT be continuity on the top 2 contacts, there SHOULD be continuity between the bottom two. If this is what you get, you're getting there. Tighten the screws and reconnect the plug.
NOW, the other plug, the one that connects to the wires coming out of the TPS. Unplug it. You will see 3 contacts in there also. Check the resistance reading between the center contact and either of the outside ones. You should get a reading of about 1000-3000 ohms from the center contact to one of the side contacts, and about 9000-11,000 ohms between the center contact and the OTHER side contact. If it checks ok, now check it again, but with the gas pedal to the floor. The resistance readings will be the opposite of what they were. The center to side contact that had 1000-3000 before should now be 9000-11,000 and the one that had 9000-11,000 ohms should now be 1000-3000. If this isnt what you get, or if the readings are way out of this range, replace the TPS. If it checks ok, you're almost done.
Plug everything back in and start the engine, if it idles where it did originally, you're done. If it is idling about 100-300 rpm higher, rotate the TPS, in tiny increments, towards the top/back until the idle returns to normal, then tighten it up. You're done.
Now, there are I think 3 plugs, between the battery and the coolant tank. Make sure they are all plugged in. If not, do the obvious. If they are plugged in, unplug each one of them and check the contacts to make sure they arent gunked up or corroded. If so, clean them up, if they look ok, plug them back in.
Take if for a spin. If it shifts ok now, send me a beer. If not, I would replace the transmission control unit (ATCU). Yes, its under the passenger side kick panel by the engine ECU. You should be able to get one in a junkyard or off ebay pretty cheap. If after all of this it still doesnt shift right, pull your hair out. I would.
If you dont want to do any of this, drive to Cincinnati and I'll do it for you, I've done it a million times. Let us know what happens.
