94 Altima won't start, cranks
General discussion area for the U13-chassis Altima
cookae
Car: 1994 Nissan Altima
My 1994 Nissan Altima won't start. The engine cranks well, it first didn't start when it was really cold outside. I got it to start when it warmed up, but now it won't start again. I already replaced fuel filter, engine coolant temperature sensor, distributor cap & rotor. I checked the spark from coil, jumped .5". Also saw spark from each spark plug when I pulled them out. After I cranked engine, I pulled each spark plug and they were wet with gas.
What should I try next?
marlin29311
Car: 2008 Infiniti G35x
How's your battery?
cookae
I'm not sure how old it is, but it seems to turn the engine over well. I have tried to jump start it several times, and that doesn't help.
Thanks.
jeremu
Car: 1994 Altima
Maybe it's flooded.What happens if you push the gas pedal all the way down and crank it?
jeremu
Car: 1994 Altima
It might also be one of your sensors.Is the check engine light on?Do you know how to Check your codes?
it could be the CPS (crankshaft position sensor) or ECTS (Engine Coolant Temperature Sensor.)
cookae
I thought it might be flooded, so last night I removed the spark plug to let the gas evaporate. I will see if that works later today. I didn't know about holding down the gas pedal and cranking the engine, but I will try that as well. I already replaced the ECTS, and I read if the CPS is bad there will be no spark, but I've seen the spark plugs spark.
Thanks for your help.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
you may have intemittent/misplaced spark. U13 are infamous for leaky distributor. look UNDER the dust cover which is under the rotor for signs of oil tracking.
see thread below from Novemberish. i think it was jackblue.
cookae
Thanks that was it.
I opened up the distributor and there was a lot of oil. I cleaned out the oil and it started right up. Now I just need to replace the distributor.
jeremu
Car: 1994 Altima
SCORE!!!I have a 94 Altima and I would have never guessed this.Now if this ever happens to me I'll know know one more thing to check.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
good work. temptation will have you run down to your local parts monkey and take whatever he has.
once again: non-OEM at your own peril. genuine nissan remanned is probably less than you think from one of our sponsors.
http://forums.altimas.org/zerothread/349111
http://forums.altimas.org/zero...-runs
Return to “1st Generation Altima Sedan (1993-1997)”
