'94 Altima GXE Issues
General discussion area for the U13-chassis Altima
bottomgun
These are my issues:1- After running and the engine is shut off, it doesn't want to restart on the first try. Within the past year, I have replaced the Ignition Coil, Neutral Safety Switch, Ignition Switch, all plugs and wires. It always starts on second try.2- Touch the brake peddle and the clock goes out. All brake lights work.3- Flasher clicks at double speed until I turn on the turn signal and they work. That clicking is annoying. All bulbs work fine.
baalpeteor
did you ever get this fixed? If so what did you do about the brake putting out the clock? Mine does this right now
Return to “1st Generation Altima Sedan (1993-1997)”
