acuevas123 »
https://forums.nicoclub.com/acuevas123-u164672.html
Mon Jun 06, 2016 8:57 am
Hey folks,
First off thanks to everyone for their help.
I have been dealing with a pestering issue of over heating with my 94 Altima.
A few months ago my radiator broke while on the freeway and barely made it home.
I changed the radiator, water pump, and thermostat all new. Removed the intake manifold to replaced the water lines and hoses behind it. Also, pulled a used intake manifold and AIC valve from the junk yard(the donating car had only 120k miles) and replaced those. Thirdly, since the manifold was off I also replaced the temp switch, heater switch, pcv valve, knock sensor. I also flushed the heater core.
No white smoke from tail pipe, no bubbling at radiator cap(have not done block test) and the oil cap does not seem to show moister. No visual signs of a cracked head gasket.
Can turns on good, idles well and warms up and hold normal temp - just below halfway point. No visible water/coolant leaks. The issue of overheating comes into play when I run the vehicle after about 20 minutes. It begins to over heat and both radiator fans come on and spin faster as vehicle increases in temp.
The only two things that I have noticed is that the radiator hose, on passenger side, that runs from top of radiator to engine at the valve level makes a "gurgling sound" when car is off. Also, the fluid reservoir has water in it and not coolant. Maybe the water is just left over from previous.
Any all all help is most welcomed!
