acuevas123 »
https://forums.nicoclub.com/acuevas123-u164672.html
Wed Sep 16, 2015 11:12 pm
Hi All,
I have had idling and pulling/jerking issues with my 94 Altima for a while.
I placed a new distributor and used ECM and that seemed to fixed the issue for a while.
Recently I had timing belt and glides changed. After that repair the car would stall at stops and idle erratically. I then replaced the coolant temp sensor thinking that could be triggering it.
Now my Altima is intermittently stalling when I place vehicle in park.
Also, the rpms will drop significantly when coming to a stop. The rpms will go from a normal 6-7k rpms and drop to 1-3k rpms and bounce right back up to normal range. Any ideas are most welcomed.
Regards,
Andy
