elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Jul 01, 2013 9:11 am
Normally when you turn the switch, there is a green light on the dash which says "HEIGHT" will come on when you turn it from N to H. That could be because of the fluid.
I might check the trouble codes.. Do a search for checking the active suspension codes, and report back if you find anything. Note that code 55 is "all is normal".. IF you have any codes, that would be a good place to start, plus it only takes about 5 mins to do.
