Q45tech wrote:Maximum instanteous peak acceleration always occurs at the torque peak rpm [~~4,000 rpm] and declines thereafter.
Since tcu shifts are controlled by speed and rpm mismatching the tcu and transmission by 5% can cause some variable responses. ......in 1st and 2nd shifts.
First, if I put the later transmission in my 90 Q, and use the later TCU, should I use the original ECU or the later ECU? In either case I want to have the NICO modified version.
Second, the reason I'm interested is because the shift from 2nd to 3rd in my transmission is slow and drawn out, expecially when it is colder outside. It can take one to three seconds. It was about 55 degrees out today, and I could still notice a slight hesitation. When warmed up, it seems to work fine, even under full throttle. My car has about 96,500 miles on it and the transmission has about 60,000 miles on it.............any ideas or suggestions for a cure?
I am about to take the car off the road again and do the brakes, fuel pump, and anything else it needs, so any help you can give will be greatly appreciated!
Thanks..............John
