The only experience I've had is my Q with Dinan ecu, stock exhaust, and intake against another Q wiith a Japanese take out engine where the installler didn't change the exhaust manifolds, had JWT ecu and loud exhaust and intake [hot air cone].
Rolling 55 mph Up to 130 mph it was give and take side by side losing and gaining half car lengths............learned all I wanted to know from that 25 second experiment.
Lots depending on shift points, my high miler [220k at the time seems to have more between 6,000 and 7,000 wheras the newer engine had more around 4,000-4,500.Should have been the opposite if the precats' backpressure was meaningful.
Guess the question is was the engine development work done with or without precats [since they knew they would sell 10 times more Presidents in US than Japan.
Above 4500 rpm the VVT decrease the valve overlap from 28 to 8 degrees seat to seat so one could assume there is NO exhaust reversion to dilute the incoming charge.The US and JDM cams are the same as are the headers [except for welded on precat].You can't control your overlap without changing the cams, but the effects caused by changing the back pressure are the same. When you reduce back pressure, it is equivalent to increasing valve overlap, and when you increase back pressure, it is the same as decreasing the amount of valve overlap.
As to precats/cats you just unscrew the O2 sensor and make an insulated hose attachment [metal] and metal for a few feet before heat resistant rubber to a zero to 10 psi gauge [taped to windshield] and measure the back pressure under idle, cruise, and high rpm load.........worse the higher you go.
http://www.jdsdiagnostic.com/eptspage.h ... twork2.htm
Another thing is the EGR back pressure calibration without the precats the EGR amount may be insufficient to pass the NOX emission test [?]
http://www.installuniversity.c...e.htm
Some scientific testing shows that for for an exhaust system say from the O2 sensor back to only reduce power by 1% the system must flow 2.2 cfm at 20.4" H20.
"The tests came about because Kevin has developed a patented variable flow exhaust that uses a butterfly within the exhaust pipe. He initially expected to use the system to cause some back-pressure at low loads "to help torque". However, he soon changed his mind when any increase in back-pressure proved to decrease torque (and therefore power at those revs) on a properly tuned engine! What increasing the back-pressure does do is dramatically quieten the exhaust.
One of the engine dyno tests carried out by Kevin was on warm 351 4V Cleveland V8. Following the extractors, he fitted a huge exhaust that gave a measured zero back-pressure. Torque peaked at 423 ft-lb at 4700 rpm, with power a rousing 441hp at 6300 rpm. He then dialled-in 1.5 psi back-pressure. Note that very few exhausts are capable of delivering such a low back-pressure on a road car. Even with this small amount of back-pressure, peak torque dropped by 4 per cent and peak power by 5 per cent. He then changed the butterfly position to give 2.5 psi back-pressure. Torque and power decreased again, both dropping by 7 per cent over having zero back-pressure"
Now all we have to do is measure a stock good Q back pressure and define some limits as the old rule of thumb that a 3 psi back pressure is ok at at 2500 rpm cruise is obviously less than ideal.
http://www.asashop.org/autoinc/nov97/gas.htm
