boogar »
https://forums.nicoclub.com/boogar-u44423.html
Sun Jul 30, 2006 4:08 pm
Well....after alot of reading of nissan scematics and looking at totaly usless info on the web, I found out this bit of info...The Clarion "active sound" system is totaly diffrent than the regular stock set up.
If anyone out there is tring to add a new head unit or a whole new sound system, I might be able to help out with this one.
I used most of the factory wires , with no need to rewire doors and rear speakers.
Also, I found all the correct wires for power and so forth, seeing as how the plugs may look the same for this "active sound system", but an after market adaptor harness wont work, for either the 94 or 95 clarion system.
One surprise I foundwas the Carbon fiber cone clarion speakers I found as a stock speaker.....the foam was rotted out but still...carbon fiber, for a stock speaker.
Anyhow ..Im all geeked about the sounds comming from the pathy.
If anyone needs help on their 94 or 95 pathy with the "active sound system" BY clarion...Im here to help
Boogar
