Wes-#3 are you saying that the core must be a working ECU ?elwesso wrote:Just got word on friday that the NICO ECU's for the 94-95 Q are ready...
Heres the deal, basically just like the 90-93 ECU except.
1. We dont have much flexibility, we can only give you a basic reprogram.2. We have no cores.3. You must supply a core that is one that you intend on using for your car, meaning you cant just supply a core and we'll make it work.4. I can help you decide what ECU you need, and check the ECU numbers.
Finally the price will be $125
LIke OI said, we do not have any cores available that we will sell without some sort of exchange... You are responsible for sending us an ECU that you konw works, and we will program it, and then send it back. If you want to reprogram your 90-93 ECU, we can probably do that.pdqwrx wrote:Wes-#3 are you saying that the core must be a working ECU ?
Are you running the same basic program as the older cars?
Do you have any older cores that will work in my 94 non TCS car that you want to sell with the new program so that I can keep my stock computer.
One way or another count me in this round....By the way, the Q goes in for paint on Monday to erase all evidence of the booboo, thanks for the doors.
CheersScott
yes sir.. fire me an emailpdqwrx wrote:Heh Wes- are you ready to go???CheersScott
RobertsnewQ wrote:No difference in tuning, but if you run the early ECU in the later car, the auxilliary cooling fans won't come on at 190 like they do with a 94-95 ECU.
Could be a problem depending on how marginal your cooling system is, but several people have run the early ECUs in their car with no problems whatsoever.
So for someone like myself who is definitely a car nut but NOT mechanically inclined, what are the pros and cons of getting your ECU reprogrammed?elwesso wrote:Just got word on friday that the NICO ECU's for the 94-95 Q are ready...
Guess I don't see the advantage of less flexible choices for the ECU. Could you elaborate why the restriction to one vs. three maps is better?RobertsnewQ wrote:I also modify the code to use only one fuel map, instead of three as stock.
Thanks for the info. The octane is not a problem as I've done everything to spec and always serviced the car either at the Santa Monica (earlier years 99/01) dealership or at the Thousand Oaks (01 to present) one.RobertsnewQ wrote:
The downsides are that increasing the timing reduces the ECU's ability to cope with low-octane gas. You must always use at least 91 octane.
