Front tension rod bolts are 17mm. The T/C rod studs are 17mm also. The rear caliper bolts are 17mmm and the front caliper bolts are 19mm. Can't remember what the hood is?tigwebu wrote:Sorry guys, but I took a week off to put my car back together, but I ran across a problem, I'm missing a lot of bolts please help me with the size so I can replace them. I need the bolt size for the followingHood, both caliper to spindle bolts (front and rear), both driver and passenger side seats, front tension rods, also tension rod studs.
Thank you guys in advance.
