94 240 vert front left tire squeaking!!!
slip69
Car: 94 Nissan 240SX convertible
07 Dodge Charger
so this has been going on for a while now. at first i thought it was the brake pads so i replaced them. it stopped for about a day and then it started again. the following week i took the brakes apart and rechecked them. when i put it back together and drove around the noise stopped again but only for a day.
the squeaking only happens when the car is moving and it never squeaks when i brake. the faster i go the louder it gets. i also noticed that when i apply the brakes i hear a single thump coming from that brake but only when i brake suddenly.i really need some help. im tired of hearing that stupid noise!!!!thanks in advance
stopatnothing
Car: Scooty Puff Jr. and NEW! Scooty Puff Sr.
I got the same thing (except for the thump) and I've been working on figuring out what it is for weeks... The only conclusion I came to is that is has something to do with the humidity because when it's really dry its either much less prevalent or nonexistent. Let me know if you figure out what the hell it is... and I'll do the same.
slip69
07 Dodge Charger
cool, i'll try sanding the rotors down. maybe that will do the trick. if it does i'll let you know.
stopatnothing
Probably a good bet, I decided to save that for last just for the sake of salvaging what was left of my 17 year old rotors but if it works definitely let me know.
slip69
07 Dodge Charger
ok so this is what i did, i bled the brakes, moved the dust cover on the rotor a few inches back using a screw driver and i did a light sand on the rotor. i did this on saturday and since then no more squeaking. so im ot sure which did the trick since i did them all at once. hope that helps. and if the problem returns i'll post it up.
stopatnothing
good deal, then thats exactly what im gonna do. did you use anything special to sand down the rotor?
slip69
07 Dodge Charger
you know im not really sure what sand paper i bought but it was from Kragen and i just got whatever was kinda rough but not too rough. you know what i mean? good luck
stopatnothing
good deal, ill give it a shot. thanks!
