94 240 5-speed Swap Aftermath Question
45guy
Car: 1994 S13 convertible
Swapped 5-speed into my 240 but did not swap rear end. Cruising RPMs are a good 10% higher now. Why?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The speed sensor is off calibration. Use the one from your A/T.
45guy
Make me smart---what does a speed sensor do?
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
It's actually closer to 9.5% different. The final drive gear ratios are different by that amount between AT and MT... Thats it.
4th now should be like driving with the OD off before (3rd) as they are both 1:1 ratios. All other gears in the MT are shorter then the AT, thus another reason why they accelerate faster.
