'93t Loss of power
93 Q-SHIP
Car: '93 Q45T, '87 M6, '86 JEEP GW, '74 BRONCO, '98 740iL
My '93 Q45t with about 175k has suffered a sever loss of power. The car won't get out of it's own way. Will only pull about 4k rpm in 1st gear and won't shift under full throttle acceleration, if you can call it that.
The car also has the intermittent misfire. I cleaned the MAF sensor with brake cleaner, but this did not help.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
check your fuel pressure.
96Qowner
Car: 1996 Q45
And your MAF may be bad inside. Here's a thread about resoldering the joints:
Repairing Q45 MAF
elwesso
2007 BMW M Coupe
Thanks for the link.... HOWEVER.
TOO MANY TIMES have I seen people try and disregard fuel pump problems because its "not making noise". Ive seen this 3 seperate times, one time someone replaced a whole bunch of crap before finally figuring out his fuel pump was bad.
Check fuel pressure before you do ANYTHING ELSE. Otherwise, youre just wasting time and money.
In my experience, MAF failures are more of a rough idle/stalling issue.
96Qowner
Car: 1996 Q45
The 4000 rpm number has been linked to the MAF before (also fuel pump or FPCU), and he has intermittent misfires.
But, yeah, gotta know what the fuel pressure is.
elwesso
2007 BMW M Coupe
MAF failure is 2000 RPM with a CEL.. Im leaning toward that not being the case.
96Qowner
Car: 1996 Q45
I stand corrected. Thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:TOO MANY TIMES have I seen people try and disregard fuel pump problems because its "not making noise". Ive seen this 3 seperate times, one time someone replaced a whole bunch of crap before finally figuring out his fuel pump was bad.
Exactly. MAF sensor wires are seldom bad unless air filter change intervals are too long or the dreaded K&N or aftermarket CAI is used.
MAF connector and FP are always the prime suspects. Why fuel pressure is measured first always.
Modified by maxnix at 10:28 AM 12/11/2007
93 Q-SHIP
Thanks for the tip.
Has anybody experienced plugged precats or catalytic converters resulting in similar symptoms? My '86 Jeep had a plugged converter and wouldn't go faster than about 50 mph. Got any ideas on how to check for a plugged converter. On the Jeep, I used the manifold vacuum to troubleshoot.
Thanks,
elwesso
2007 BMW M Coupe
Its happened on the 94s a couple times, but not really common... most ofthe time its the precats melting due to bad injectors.
93 Q-SHIP
Thanks for directing me to the fuel system. Turns out the problem was a plugged fuel filter. I thought that I had changed the filter a few years ago when I bought the car, therefore I didn't think it could be the filter, but turns out I didn't.
I have purchased a new car and want to sell the Q. If you know of anyone looking for a Q45t, please have them contact me. I'll be listing it in the For Sale posts in the next week or so.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
93 Q-SHIP wrote:Turns out the problem was a plugged fuel filter. I thought that I had changed the filter a few years ago when I bought the car, therefore I didn't think it could be the filter, but turns out I didn't.
Yeegads! Annual filter replacements are required! Fuel filters are very limited in capacity.
Still can't find anything for which I would want to part with my 1995. What did you choose?
93 Q-SHIP
I bought a '98 740 iL.
Alpine White, Grey Leather interior, K&N air filter, Bilstein HD shocks, H&R springs, Remus Stainless Steel Free flow exhaust system, 19" AC Schnitzer type III wheels 8.5" (front) 9.5" (rear), Bridgestone Potenza tires - 255/40YR19 (front) 285/35YR19 (rear), AC Schnitzer pedals.
I think that the Q-ship is a great car. However, it's time to move on. I don't have the time to refurbish it. I would like to sell the Q to someone who appreciates them.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Nice car. I would like to see the wheels.
Think about going back to an OEM air filter if the engine has a hot wire sensor like the VH45DE.
I like German cars, but having owned them, I prefer the Japanese reliability and lower cost to maintain and repair. Still.....
Modified by maxnix at 12:07 PM 12/18/2007
93 Q-SHIP
Send me your email address and I'll send you a couple of pic's.
Or tell me how to include pictures on a post.
Thanks,
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
93 Q-SHIP wrote:Send me your email address and I'll send you a couple of pic's.
Click on any member's name to email (if it is enabled) or read the sticky on picture posting.
In any case, come back and keep us updated.
