93s13a coupe upper heater hose replacement
93s13rookie
Car: 93 s13 and 90 q45
I recently replaced my upper heater hose and the water pump. Bleed the system of air and it still overheats. Any recommendations? I used the bleed screw a few days ago and it still overheats......ok I know it doesn't have a sr20 or a rb but I need some help.
SQUAREroot
Did you check the simplest option, the thermostat to make sure its working?
pepesilvia
Car: 96 S14
^^^^^^ this. if your thermostat is stuck open yur car will overheat. Most common issue i believe. get it replaced.
