kandypurpRPS13 »
https://forums.nicoclub.com/kandypurprps13-u237709.html
Sun Jun 22, 2014 5:35 pm
93 s hatch no start after rebuild
car wont start after rebuild
all new fuses and relays checked
new coil
dizzy from runnin car
new coolant temp sensor
maf from running car
ecu from running car
3 different engine harnesses
pulled injectors/ no leaks
plugs black and wet
tested ignitor
new fuel filter
new walbro255 pump
new tomei fuel regulator
new wires, cap, rotor
new tps and recalibrated
0mi on motor yet ka24de
pulled engine harness and ohmed out good
to start now I have to pump gas pedal and itll start turning over faster eventually to start and sound great a few seconds and then just like it drops a cylinder or something and if pedal is blipped on cable return it picks rpms back up to around 1700 until feels like timing falls out and have to play with pedal to wake back up..if a lot of pedal applied at once it stalls immediately
