landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Wed Nov 06, 2002 6:15 pm
If it all turns out for $107, you did very well! The model year is coded into the part number, so if 64U20 is an accurate part number, then yup, it's a '93 TCU. Be aware that the part number is printed on the removable cover of the unit -- they can be switched easily. In fact, my '93 TCU has a '92 cover on it, and so shows the original '92 part number. (That'll confuse someone some day.) I've never looked closely at the circuit board to see if the part number is there, too.
As for installation, this is an incredibly easy switch to make! 15 minutes, tops. Entry sill pops off, kick panel might have a couple of screws holding it in. Get the biggest-headed common Phillips screwdriver to remove the screws that hold the TCU in place. The more common regular Phillips screwdriver will likely strip the center of the head and leave you looking for the bigger screwdriver anyway. Someone suggested using an impact driver on these screws about a year ago, but I didn't find that necessary at all. A bolt holds the harness to the unit. When the unit's protruding plastic tab (blue or red?) is flush with the back surface of the wiring harness, it's tight enough. Don't overtighten or you'll break something.
My old '92 TCU went into a box in the trunk, and that's where it will stay. Unless h-ll freezes over and I need to drive in snow. My 1-2 shift is smooth as silk at light throttle, peasantly assertive at mid-throttle, but it flairs just a little at full throttle. This could be the shiftpoint vs. max rpm debate I described, but more likely, it's symptomatic of a transmission whose line pressures are in decline. That's okay -- I bought the car knowing it was far from new, so I do what I can to prolong the second (?) transmission's remaining life, like installing first-gear starts with a '93 TCU. This was the best $200 I've spent on the car so far.
