cheap_sticker05 »
https://forums.nicoclub.com/cheap-sticker05-u27344.html
Thu Jun 17, 2010 5:54 pm
Okay so here is the situation. My car has a pretty basic setup and ran fine prior to me putting a ISIS intake manifold, front mount, and intake pipe on the car. The car was already tuned for 550cc injectors, s15 t28, tomei pro cams, at 13psi. (rom tune)
Right after I started the car up with the new stuff on, the car would not idle right. Adjusted tps, and iacv. Got the idle somewhat under control, then noticed the car still didn't feel right so I did a boost leak test. I found a few major leaks, good, should run better now. Nope it ran worse, in boost it would completely break up and have no power even down low. Bought a wideband, installed that, reset timing thinking it was a little out even though I had never touched it. I also fixed the exhaust leak at the manifold to turbo. Now here is where things got worse. Found that the timing was a bit advanced from when i got the car. I set it back to stock and its even worse than before. My afr's are a bit rich at idle 13.0 to 13.5, probably just the tune, and the second I give it any gas it goes straight to 16-17 afr and breaks up bad. I am so lost what to do next. This car was fine until I put this crap on there.
What I have done so far-
-boost leak test, both on hot motor, and cold, found leaks and fixed them
-verified tps voltage was at .45 when closed
-adjusted iacv to get idle down
-verified all the injector ohm readings are correct and that all checked out fine 13ohm
on all
-tried mafs, and coil packs/harness from a known good car
-afr's are 13.0 to 13.5 at idle, anytime the gas is hit it goes straight to 16-17afr and
never goes lower in boost
-fuel pressure checks out 37psi w/ vacuum 43 without
Please give me some suggestions what to do next. I don't know if I should change the tune? I would just put the car back to stock like it was, but thanks to my mom and her eye for aluminum, my intake has now been recycled with the aluminum cans -_-
