Spooled_GTIRSENTRA »
https://forums.nicoclub.com/spooled-gtirsentra-u47677.html
Wed Jan 31, 2007 8:15 am
ive had alot of problems with wiring with this swap, they sent me a hacked up harness with alot missing. im down to my last few wires. there is a harness clip that is close to the battery. there is three clips together. one is for the starter the other is for the injectors and the other i cant figure out. there are 2 wires goin to it red/black and black/red. i wanted to see if the clip had anything to do with the coil not getting power so i grabed my volt metter and put it on the setting that tells you if they are connected. when i touched the b/r (clip) and the b/r (coil) it beeped saying they are conected somewhere. then i tried the other 2 wires r/b(clip) and the g/y (coil) and it beeped again. ive looked at the wiring diagram and cannot figure out why its not getting power and where this clip goes to.
thanks tony
